elbes14
So i'm about 50% complete my cafe build and ran into a little bit of a snag. I hooked up my aftermarket signals which are all working properly. Along with the new signals I've decided to make a custom dash with 3 lights,
1. Neutral switch
2. Oil Pressure
3. Turn Signal (just a single light like stock Kawi wiring harness)
I have hooked up everything as was hooked up on the stock harness. Oil and Neutral lights are working just fine. As for the signal indicator it only blinks for one side where on the stock hookup will work on both sides. I'm assuming I am having this problem due to the fact I switched to LED indicators from the regular incandescent bulbs. My question is if there is a way to make my setup work without having to install another turn signal indicator I'd really like to keep the 3 light system.
1. Neutral switch
2. Oil Pressure
