modifiedamerican
still trying to wire up my mini NON led blinkers to my kz750. i can get them to all come up but can not get them to blink. also switched to an electronic flasher relay.
The 2 front lights are mounted to brackets ground the housing of the lights to the frame.
The front lights have 2 positive wires, one that goes to the back that supplies power to the rear blinkers.
The 2 rear lights housing are grounded to the frame. With 1 wire connected to the front for power. The other wire is a ground that doesnt seem to make a difference if its grounded or not.
The turn signal indicators stay on with the key on.
And on the flasher relay one wire tests a constant hot, and the other wire turns on and off with the turn signal switch.
here are the lights that i am trying to hook up.
and heres some pictures of how i have everything wired up. u should be able to zoom in on the picture to get a closer view.
Front indicator turn signal lights
front blinkers wires up
Rear blinkers wired up
me and my buddy are stumped so everyones help is greatly appreciated!
