www.Moto-Madness.com
Author Topic: Back at it....this time with an 81 Suzuki GN400.  (Read 54319 times)
Offline ajeevisser
Re: Back at it....this time with an 81 Suzuki GN400.
« Reply #130 on: Apr 08, 2013, 07:40:34 »
There are two little  holes covered from the spacers then.
Think they are some sort of oil channels.
Any problems with that?
Offline cierrecart
« Reply #131 on: Apr 08, 2013, 16:23:29 »
Nope.  They work great.
Offline Dec79
« Reply #132 on: Apr 08, 2013, 17:32:51 »
Love it  8)
Offline reesea17
  • I'm probably gonna ask a lot of questions...
« Reply #133 on: Apr 09, 2013, 12:12:19 »
Does anybody know if the forks of the Holiday Customs GN400 are lowered internally?
It looks like they are just lowerderd in the steering stem.
My fork seals are leaking, so I've got to rebuild mine anyway.
Almost positive they're lowered internally.  I tried just sliding them up in the trees and the front end was just way too high.  Internal is the way to go.   I took 3" out of mine.
I actually emailed Jared a little while ago asking how he lowered the forks on the CB450 projects he'd done and all he said is that he cut the springs in order to shorten them.  Not sure if thats 100% the only thing he did but it seems an easier route then having the fork tubes themselves machined and shortened down.  I think I might take the spring cutting option to my forks and see what happens..
Offline cierrecart
« Reply #134 on: Apr 10, 2013, 03:22:05 »
If he cut the springs, then he likely added spacers, which is what actually causes the lowering effect.  That's what I did on this bike.  No need to do anything to the tubes themselves.
Offline ajeevisser
« Reply #135 on: Apr 11, 2013, 11:23:47 »
I made some 2" spacers. Think that's the right way to go.
Cierrecart used 3" spacers and his fork is very low.
Is it right I have to cut the springs 2" too?
Offline tafspeed
« Reply #136 on: Apr 14, 2013, 14:30:34 »
Cut and shaped a Walmart workout may today.  Glued 3 layers on, cut to shape then used a flap disc to shape it a bit.  Should be good enough.  I plan to have it professionally upholstered.  Looking at black leather/vinyl with red stitching in either tuck n roll or diamond pattern.
What glue did you use to stick the layers together and to glue it on the base?
grtz
Manu
Offline cierrecart
« Reply #137 on: Apr 15, 2013, 01:40:27 »
I still have decent travel and plenty of clearance.  You can cut the spring the same length as the spacers you added, or you can do like me and leave them a half inch longer to add some preload when you put the caps back on.
As for the glue, I used good old Super 77 spray adhesive in the can.  ;)
Offline ajeevisser
« Reply #138 on: Apr 16, 2013, 04:23:14 »
If I use a 2" spacer and cut the spring 1.1/2" , how much fork oil do i have to add?
Offline johngchrist
« Reply #139 on: Apr 21, 2013, 22:24:46 »
Love what you have done with your bike. I just started in on my 400 and was wondering what you did with the speedometer throttle and brake cable.  If you got new ones what lengths did you get and how much did you end up spending?  I may just run to the salvage yard and try and find something. Just curious to see what route you took.
