NeeksRR
Active Member
Heeeeeeellooooo,
It took a cold and a day off work to finally start this build thread! So here it goes!
A little background on me from my intro here - http://www.dotheton.com/forum/index.php?topic=44100.0
So Ive always admired builders and what they create. I've just been shy to commit to a project because of my lack of knowledge of engines and electrical. But when I came across this sale in another riders forum im active in, I saw that this would be a perfect time to start to learn. The guy had 2 1/2 bikes roughly in parts in boxes all over his garage. One was a complete CL160 which he said is a 66', but he tore that down into parts to transfer into a CL175 frame. I guess he had plans to later pick up a 175 engine once he found one. One of the cool scores, was he had already bought all need bushing, gasket kits, oil seal kit, etc. to get everything fresh. ANYWAYS... I got 2 engines, both 160s and only one runs, the other is stuck...Ill look into that way later. Gave the dude 300 bucks and took off (This was about 8 months ago)...
Here is when I got home to start loading all this junk in my man cave ;D
My Build Plan -
Well I dont know a whole lot about all the different styles and terms for what I want in the end for this build, but I do know Im going to try to incorporate my strong skills to make it my own. Im a decent welder, decent painter, but most of all Ive worked with wood/construction for the past 15+ years. So I plan on doing some fun wood work into this one. Ideas for where the wood will go....Well once I grind out the batt tray and get that area all cleaned up I want to make a fitted number plate with the number "18" cut out and back lit with some little lights on each side of the bike...The tank, headlight bucket, and cafe tail will have "racing stripes" in wood all the way down the bike... And still thinking about doing a wood seat pan. Drop the bars...maybe a different gauge set up if I can figure it out. Soooo....yep, thats "the plan"! haha
Here it is as it sits today -
When I first got the bike I tried to go through the 5 boxes of parts to find the best ones to put into one bike...
Then once I found (what could be a complete bike) I started to go through the electrical to make sure everything was hooked up just to get it started.
I took the carbs apart to find that there were in pretty good shape! There was almost zero gunk and just some haze from old gas. Cleaned that up real good and reassembled them and back on the bike they went.
I turned the key and started kicking...Never checked the compression but it seems to feel and sound good when I would kick it. It wasnt firing or even trying so I started with the plugs...they were fine...Then to the new NGK insulators the guy put on, took the plug out and check for a spark. It was pretty weak and sometimes not at all. So I pulled the plugs off to notice he did a shitty job of putting the new insulators on. Cut, exposed the wire, and reattached the NGK's and got a nice big spark
(Keep in mind I couldnt find a throttle tube and housing, was only controlled by the choke)
So I slapped it up to full choke, 1 kick it fires right up!! ( Also keep in mind I've been half ass working on this for the pass 8+ months with not one sign that it actually runs) I was so excited that it was running that I couldnt think of how to kill the bike, it had no throttle or kill switch, at this point the bike is scream at full RPM's and starting to smoke...Im panicking and just pull the spark plug caps off and the bike dies! LOL! (Of coarse later I realize I could have just turned the fuggin key to off!) Im laughing to my self that I almost blew it up with only running for 16 seconds of life. My roomie comes down wondering what the hell that screaming was and why it smells like shit in the house...I raise my hand slowly with a big smile on my face and let him know I brought life to this POS that use to be parts in boxes. I felt like that was probably going to be a more memorable day then having a kid : ....I could be wrong.
So now that I know It runs and I seem to have all I need to finish this badboy, here is my new list of things to do before I continue anything major....
- Never got a title for any of the bikes...I was told they have been out of the system for so long that all I have to do is start the new paper work for the DMV. I have a CHP friend that offered help once it comes to an inspection and whatever else needs to be check off so I can get a new title.
- So this leads me to my first question... Can anyone share a link or let me know how they best handled doing this??
- Next, figure out what frames and engines I have!!! Haha. I figured I post up the serial numbers up here and see if anyone knew, so here they are!
- Engine #'s
- (Running) L160E-1005844 & (Frozen) B160E-1031838
- VIN #'s
- CL160-1005884 & CL175-1012680
And of coarse, I feel a picture that best represents me as the nutty fun retard I may be....Here ya go
Racing is another thing I love to do so here is my 600rr
Thanks for looking and hopefully I can get a lot down this winter for some spring cruisin on my future sex machine CL160 Cafe 8)
My Build Plan -
- Engine #'s
- VIN #'s
