Well, the way I see it, you are risking compromising the frame strength and rigidity for cosmetic reasons.
Fully welding the flange would increase the strength there, but removing it reduces strength. The frame needs to resist buckling, the flange increases the moment of the cross section and helps stiffen and resist buckling. When you remove the flange, you really reduce the strength. Think of an I beam. You are removing the center of the i beam. Even with thicker metal there, the frame will flex more.
If you are making a non-riding museum piece, go for it.
If you intend to ride safely, I think you are foolish to play with structural integrity. These frames are not the stiffest in the world, and the modification you are making will reduce the stiffness more.
Just for your own education, take a piece of 1/8 inch thick flat stock, 2 feet long. Hold it on one end. wiggle it back and forth and watch it bend. Then take a piece of angle stock. Same thickness. You can see how much stiffer it is. It is not the thickness of the stock that makes it stiff, the right angle bend adds to the moment of rotation and stiffens it. Angle stock is not "stronger" than flat stock, but it is stiffer. You are converting your frame from angle to flat. Even making it thicker will not make it much stiffer.
So fore warned is fore armed. You can do what you want. Others have done it, and that doesn't make it good. You are playing with basic engineering of the frame, blindly. If you calculate the moments, and put on sufficient material to regain the stiffness, then you are doing it right. But I don't think you are doing that and are playing with your own safety.
Had my say.....Good luck...you'll need it.
