I've seen some good enough results using vht engine enamel on tanks.
I have a few questions..
1) If I'm going to cure the engine enamel in the oven, do I do this before or after the last clear coat?
2) If I use an etch primer that is not used for high heat application will I be ok? I also have the VHT primer which I assume is not an etch primer, so should I use this instead.
