I just started to hook up my Pamco ignition to my '75 750F. The wiring seems really goofy.
There are six wires in total, grouped into two harnesses. Both triggers are green. Then there's a black ground wire from each board, and a red power wire from each board.
I'm hoping I can just ground the blacks to one of the three plate mounting screws. Splice the reds together and run them out of the case with the two triggers (color keyed with shrink wrap) That way I've reduced the wires to only three which I can wrap neatly.
The plate screws are grounded right?
