www.Moto-Madness.com
Author Topic: Re: Piglet  (Read 56817 times)
Online irk miller
Re: 72 CL100, All in the Family, build.
« Reply #10 on: May 10, 2015, 18:56:20 »
Is this your carb right here?
If so, it's the same as the XL.  You have adjustments at the needle, the jets and the air mixture screw.  The thumbscrew is your idle adjustment and basically just pushes the slide up or down.   It's hard to see in the shadow, but on the engine side to the left of the thumbscrew, there is the air screw.  Normal adjustment should be 1 1/4 turns counterclockwise.
Offline trek97
« Reply #11 on: May 10, 2015, 19:15:56 »
Quote
Just got up from my big ole nap.
Yep same carb.  and THANKS.  I saw how the idle speed adjuster worked on the slide.
Im gonna re-attack the points.  The pic in manual is kinda showing what you described about the plate mark.  Its close to 0 also.  Gonna move it and see what happens.
Maybe I am finding the reason Uncle parked it in the shed.
Offline trek97
« Reply #12 on: May 10, 2015, 20:12:15 »
OK just to catch back up.  w pic
Heres the carb after soaking in pool for about an hour or so.
Also, while I had the carbs soaking I pulled the air filter.  It didnt make the "journey through time" very well.
Like Eric suggested I re-adjusted timing. Closer to factory marks.  and after the third kick she fired up and ran good for about 30 seconds.  Of course no camera handy enough.
But, now she wont start again.  So, gonna double check timing and make sure things are good an snug.
And now I got to go bake the old lady a cake and make her a bowl of guacamole.
Maybe more tomorrow....
« Last Edit: May 10, 2015, 20:58:07 by trek97 »
Offline trek97
Re: Rachels, 72 CL100, First (documented) Start up.
« Reply #13 on: May 11, 2015, 21:56:14 »
DAY 3
Shortly after cleaning Plugged pilot.  ::)
« Last Edit: May 14, 2015, 06:51:47 by trek97 »
Offline trek97
Rachels, 72 CL100, First (documented) start up
« Reply #15 on: May 11, 2015, 22:27:16 »
fully restored 100 kick honda for sale.  $4500.00
new oil,  just needs finishing.  mods include updated air in tires.
« Last Edit: May 11, 2015, 22:34:37 by trek97 »
Offline trek97
Re: Rachels, 72 CL100, First (documented) start up
« Reply #16 on: May 11, 2015, 22:41:25 »
Seriously, Now I feel a lot better bout this project!   8)
So far I got a grand total of
$26 battery
$2.59 spark plug
$28.59 total
the oil, fuel line, carb cleaner and penetrant I already had.  Leftovers from the $6 million dollar build.   ;D
Offline Bromz
« Reply #17 on: May 11, 2015, 23:07:06 »
Atta boy!!
Chris
Offline Thomas_Hudson
  • Honda owner/Honda Rider
    • How I destroyed a perfectly good motorcycle. The GL500: Left4Dead
« Reply #18 on: May 12, 2015, 00:16:00 »
Nice.
Care taker of: Project:Left4Dead and Uncle Billy's Bike
Project: Left4Dead. http://cx500forum.com/forum/garage-wall/26082-how-i-destroyed-perfectly-good-motorcycle.html
 If you ride fast and crash, you are a bad rider. And if you are a bad rider, you should not ride motorcycles.
                                 Hunter S. Thompson
Offline trek97
Rachels, 72 CL100, Help hunting tires?
« Reply #19 on: May 12, 2015, 08:27:55 »
These Michelin gazelle M62 tires are about the only thing I can find.  That would even be close to a more aggressive dual sport tread.  That comes close to stock sizes.  They are rated for 92mph.
3.00-17 rear
2.5-18 front
any suggestions?
http://www.motorcycle-superstore.com/11893/i/michelin-gazelle-m62-moped-tire?SiteID=SLI%7C2.75-18&WT.MC_ID=10010
