Zoöid Third Times a Charm CB175
Re: Third Times a Charm CB175
Zeke named this bike Zoöid because of the trapezoids he milled into the front hub and since we are zoomerz their is a Zoo in Zoöid. It also has a cool meaning if you care to look it up. So Bryan sent Zeke some sketches with trapezoids in the design.
teazer said:
Zeke, that is awesome and way neater than any I have done. Nice work.
Pat, You will end up in trouble for child abuse keeping him working so late ....................... ;-)
Just want you to know he worked 80 hours in 5 days lol and he said "that was the best vacation ever!!!!" Lol I guess when you love to do something time doesn't matter.
Ok so Monday morning their designs were on the table.
The first thing they decided was to remove the rear of the frame and narrow the center of the frame we braced the swing arm that we had stretched earlier
I was assigned to take the forks apart so we could also cut and lowered the front fork tubes
8pm on Monday evening we were gazing at this hole sitting on the couch looking for the muse and Bryan said where is that shock?
This is what happened.
So I did a little research and went to Tony Fowles site and found some inspiration
Beginning of day 2 we were off to the shop with some furry friends
Zeke started shearing pieces so we could box the frame and I was assigned grinding
Tuesday 6 pm Bryan and Zeke finished bending and tacking the rear swing arm meanwhile I was making a gusset plates for the top and bottom of the swing arm and reinforcing the rear of the center frame
https://vimeo.com/133891999
Foxy shocks in place...notice the trapezoids. Bryan took a steel round bar tapped it for the shocks and then drilled the frame for installation.
This is the drawing they decided to work from as you can see by day 2 changes were evolving
