Removing wires from alternator plugs
45exmayor
I need to remove the wires from the plugs on the alternator harness to slide new sleeps over them (they are wrapped in old tape now). I have tried the smallest screwdriver in my mini set with no luck. Is there a tool or a trick?
Thanks,
Rick
tools like these should do it:
http://www.waytekwire.com/item/422/?gclid=CIm6y-Xtg8YCFciRHwodsCYAsA
Sure would like to see that little CB100.
Thanks budlite here are a couple of pics. found it as a non runner on cl last summer and have been collecting parts for getting it on road.
tool worked great. new sleeve on harness really cleaned it up. took less than an hour
wow......so you ordered one of those?
cool.
Glad I could help out.
Good looking little 100, I'm currently working on one myself.
I usually beat a piece of welding wire flat and grind it narrower. ;D
Made one from the replaceable top pice of electric toothbrush, reasonably tough stainless steel, cut off bristles and dipped in ;Liquid Tape' looks like a 'real one' 8)
I used a small screwdriver, (One of those small ones that many places give out free, ground the point longer and straighter, and viola', a removal tool.
