www.townmoto.com
www.Moto-Madness.com
Author Topic: KZ 750 Twin - Two point zero  (Read 47901 times)
Offline canyoncarver
  • 'hacking is learning'
Re: KZ 750 Twin - Two point zero
« Reply #290 on: Aug 06, 2017, 21:27:27 »
Nothing exciting to report but I'm still at it.  I got some good garage time today at least.  I cleaned up a ton of chassis hardware on the wire wheel.  I also cleaned, sanded and cleared the rear sprocket carrier for the KZ1000 mags.  Next is a bit more frame cleanup.
KZ400 The Rabbit
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
65 Norton, My damn Shovelhead chop
more YZF750R's, the KZ's, a Zephyr750...and the unfinished 75' CB550 cafe.
« Reply #291 on: Sep 11, 2017, 16:26:36 »
Re-starting on the rearset fab.  I had an extra Brembo rear master cylinder from the YZF and what do you know, it bolts on like it was made for the old KZ.
KZ400 The Rabbit
KZ 750 Twin
ZRX 1100
Offline doc_rot
« Reply #292 on: Sep 13, 2017, 02:56:51 »
good to know, what is the size of the bore on the MC? im gonna need one for a brake swap soon on my 1000
« Reply #293 on: Sep 13, 2017, 12:23:32 »
Not sure on the bore size, the rear is always a single disc so I'm going to give it a go.  I don't have the number for the caliper piston size handy either.   I'll look them up.
If you need, I have a spare one Doc.
KZ400 The Rabbit
KZ 750 Twin
ZRX 1100
Offline doc_rot
« Reply #294 on: Sep 13, 2017, 22:16:05 »
sometimes the bore size is stamped in the body of the casting. I am still undecided on the rear caliper i want to use and that will dictate the bore size I need. I think the stock KZ MC is 5/8ths. most newer bikes use small single piston rear calipers and need a much smaller MC. but like you said, try it and see how it works.
« Reply #295 on: Sep 14, 2017, 22:26:32 »
Here is the closeup of the rear master.  I'm using a very similar rear caliper to yours, mine is off a kz1000.
« Last Edit: Sep 14, 2017, 22:31:33 by canyoncarver »
KZ400 The Rabbit
KZ 750 Twin
ZRX 1100
« Reply #296 on: Sep 18, 2017, 18:19:43 »
J-Rod is making me up some folding rearsets so I started on a template that fits both sides of the bike.     Once I get the mounting holes where I want them I'll clean up the design a bit.
KZ400 The Rabbit
KZ 750 Twin
ZRX 1100
Offline clem
  • static fluff
« Reply #297 on: Sep 18, 2017, 21:53:26 »
Hey I just got a set from him for the DS7 and they look good. You'll be happy.
"After every war there are soldiers who refuse to surrender. To this day there are still thousands who cling to their 30+ year old motorcycles, thinking that the war is still on, refusing to concede that the four-strokes have won"
1972 DS7 http://www.dotheton.com/forum/index.php?topic=45886.msg505995#msg505995
1983 CB550sc bobber http://www.dotheton.com/forum/index.php?topic=30599.30
« Reply #298 on: Sep 20, 2017, 16:54:57 »
Got them last night, they look great!
So....I made some turn signals.....I found these large funky dice drilled them out to clear epoxy these neat little LED's into.    What do you think?
KZ400 The Rabbit
KZ 750 Twin
ZRX 1100
Offline clem
  • static fluff
« Reply #299 on: Sep 20, 2017, 20:33:51 »
Man that is funky. You better patent those before they are all over Alibaba for sale.
Just be sure to engrave dot approved on them bad boys.
