www.Moto-Madness.com
OUR ADS ARE FROM SUPPORTERS OF THE COMMUNITY - CONSIDER TURNING YOUR AD-BLOCKER OFF FOR WWW.DOTHETON.COM :)
Author Topic: 1973 CB500 resto-mod  (Read 7678 times)
Offline scott s
Re: 1973 CB500 resto-mod
« Reply #50 on: Apr 18, 2017, 20:01:18 »
 Also started on installation of the 400F pegs. No matter what you've heard, these are NOT "bolt on". I previously flipped the heim joint to make it a straighter shot. You also have to elongate the hole on the back of the foot peg to fit the matching peg on the frame. Oddly enough, the RH side slips right on (after removing that odd bracket).
 I prepped the 400F brake pedal to be heated and bent tomorrow. I'll also have a tab welded on for the rear brake switch spring.
Offline scott s
« Reply #51 on: Apr 18, 2017, 20:05:13 »
While I was wrapping that up, the UPS man showed up with my Speedhut gauge. I have to say, Rachel and the crew at Speedhut were a pleasure to deal with. I picked my font, background, bezel, etc., and I had them raise the red line to 12K RPM.
 They also sealed the gauge with silicone since it is going on a motorcycle and shortened the GPS cable (for the speedometer). But, coolest of all is the HRC logo I had them add!
« Last Edit: Apr 19, 2017, 19:58:08 by scott s »
Offline scott s
« Reply #52 on: Apr 19, 2017, 14:29:42 »
 Worked on fitting the front fender today. I picked up a "Harley" or universal fender from eBay because I wanted one with no holes for cable guides, etc.' I wanted chrome. And I wanted a somewhat stock look.
 I started by taping some fuel line to the tire as a clearance guide.
 I had to drill a new hole at the rear and notch the front. I also had to compress the "ears". But, we got it on. I could drive myself insane trying to get it absolutely centered, but it's close enough.
Offline scott s
« Reply #53 on: Apr 19, 2017, 14:31:10 »
That's the good news. The bad news is that while fitting the fender I noticed that the front tire is on backwards. GRRRR!!!
 I tried just flipping the wheel around, but the spacers are side specific to center the calipers over the rotors. Guess I'll drop off the tire this afternoon to be swapped around.
Offline scott s
« Reply #55 on: Apr 19, 2017, 19:56:50 »
Got a package from 4into1.com AND from Slingshot today and kept plugging away at more of the little things. Or, as Fezzler is fond of saying, "eating the elephant".
 Got the new bulb in the headlight ring, started assembling the brake hoses, and made a center stand stop. The chrome bracket was from my parts pile, probably a leftover exhaust hanger of some sort. The bumper is a Honda part. Drilled out the hole a little bigger and pressed it in and gave the hanger a bend.
 And now the center stand doesn't hit the chain or brake stay anymore!
Offline scott s
« Reply #56 on: Apr 20, 2017, 11:52:38 »
 Slingshot lines installed and routed to the Goldwing splitter.
 Reproduction master cylinder installed. I started the bleeding process, but I'll have to come back to that when I have some help in the garage.
Offline spotty
« Reply #57 on: Apr 21, 2017, 00:27:49 »
try the force the fluid up from the bottom method, use a piece of clear hose and as large a syringe as you can get hold of, works a treat and little if any bleeding needed afterwards. simple one person operation
I used it to get the 6 piston 'busa calipers sorted on the Vmax after much farting round trying to bleed them the normal way and I had it all done in about half an hour
Offline scott s
« Reply #58 on: Apr 27, 2017, 12:06:15 »
 Took a couple of 400F brake pedals....
 Heated and bent them and welded on a tab for the brake switch spring...
 ...had one powder coated "chrome" for my project...
 ...and got it on the bike today. Yes, I know the lock nut needs to be underneath. And I'll fold down the spring once everything is adjusted.
Offline scott s
« Reply #59 on: Apr 28, 2017, 17:16:56 »
 Got the Pamco wired up today, and I adjusted the clutch. Gratuitous progress pics.
