www.Moto-Madness.com
Author Topic: 1980 XT500 BUILD  (Read 12718 times)
Offline MCKAY34
Re: 1980 XT500 BUILD
« Reply #100 on: Aug 25, 2017, 00:27:49 »
Hey hillsy,
thanks mate, i will have a play with it. what does +ves mean?
Offline hillsy
« Reply #101 on: Aug 25, 2017, 00:34:43 »
Hi guys, well because the response was so fast and i solved the issue in regards to my last problem. im going to see if we can now fix this problem.
Does anyone know what these wires are for?
They are at the headlight end. I need to know what the 4 in my hand do. and also the 6 in the connection individually. I think the connection is for the handlebar switch block. But i need to know which wire does what.
Again any help would be great.
Found a wiring diagram that might help:
Yellow = hi beam indicator light
Blue  = tachometer lamp
Green/Yellow = front brake switch
Blue/Red = pilot lamp (in headlight)
Offline hillsy
« Reply #102 on: Aug 25, 2017, 00:35:22 »
Hey hillsy,
+ves means the positives for either hi/lo beam - they share the -ve.
Offline MCKAY34
« Reply #103 on: Aug 25, 2017, 00:40:16 »
thanks for your help mate, i have this diagram also, its not correct with my wiring loom. also the brake switch wires are accounted for.
Offline dakine_surf
  • "Stay Thirsty my Friends"
« Reply #104 on: Aug 25, 2017, 06:12:08 »
The bulb connectors prongs should be labeled if you pull the connector
Well I tried but I can't run no more
Tell Katie it's her that I adore
And as long as I love her best
I'm that much further west
Offline MCKAY34
« Reply #105 on: Aug 25, 2017, 08:44:52 »
Nah they arnt, but that's ok I solved the issue of the bulb wires. I just tested it on the battery so now I know what wires do what for the bulb.
Sorry everyone I should have done that in the first place.
I'm still stuck with all the other wires.
Offline MCKAY34
« Reply #106 on: Sep 04, 2017, 04:36:11 »
Rather than me throwing hammers in the garage because i cant figure out the wiring,
i have started to make a small bracket to hold the speedo.
Offline Luxy33
« Reply #107 on: Sep 10, 2017, 01:36:34 »
So good to see this coming along 👍🏼
Offline MCKAY34
« Reply #108 on: Sep 10, 2017, 03:49:45 »
Just installed the rear brake switch, i was waiting for the bracket that holds the brake switch,
Offline MCKAY34
« Reply #109 on: Sep 28, 2017, 19:16:10 »
I installed that bracket i made for the new speedo, its sits perfect, clean and low. pretty happy with it.
