www.Moto-Madness.com
Author Topic: Welding Gas Tanks  (Read 13324 times)
Offline Ryan Stecken
Welding Gas Tanks
« on: Jul 22, 2017, 16:47:52 »
Hey guys!
So IŽm a total noob to welding and my aim is to be able to weld (mainly cutting pieces out of tanks and strecthing or narrowing steel gas tanks) gas tanks.
What is the proper method for welding gas tanks?
I already have a inert gas welding machine in my shop, which I didnt activate yet...but I heard that these are not fit to weld so thin steel parts...
Hope you can point me in the right direction!
Thanks!
Offline datadavid
Re: Welding Gas Tanks
« Reply #1 on: Jul 22, 2017, 16:59:12 »
You cant do that without 10 000 hours practice or 1000 kgs of plastic padding ryan😃
Best method for welding tanks is either tig or oxy-acetylene, and practice is the only way here, with good teachers. I have been welding professionally for over ten years, and i always get the joyful task of sealing up novices leaky tanks.
« Reply #2 on: Jul 22, 2017, 17:09:32 »
Just watched a video of a guy narrowing a tank and it was AMAZING how much knowledge goes into it...wow...so I guess I have to stick to my stock tanks or dinging other tanks and trying to make them fit..  :D
Offline datadavid
« Reply #3 on: Jul 22, 2017, 18:28:55 »
Hell no, if you want to have a go, just use some scrap metal to begin with, then start making cubes to pressure test with said scrap pieces, then try to repair the leaks, then ask me or other welders how to make it 100% air tight, then try stretching and welding on a few scrap moped tanks or whatever, then ask for more help with whatever problems you encounter, then in a few years, you will be able to make amazing shit without bondo or jb weld! Its like life before and after finding out the secrets of steel man.
« Last Edit: Jul 22, 2017, 19:03:46 by datadavid »
Offline Luugo86
  • '73 CB350, '78 XS650 Cafe Killer
    • ToadStool Cycle Co.
« Reply #4 on: Jul 22, 2017, 20:14:40 »
   Sound advice. TiG would be the welding process you would want, and like datadavid said, for what you are trying to accomplish, there is no short cut. Hours and hours beneath the welding hood.
Live to Die, Die to Live
Online crazypj
« Reply #5 on: Jul 22, 2017, 21:58:06 »
 I agree, I use d-a/oxy as I don't have TIG.
Easiest way to modify a tank is cut the bottom with mountings out of the one that matches frame then cut bottom out of the one your going to use, match top to bottom and weld away. I guess it should be possible to use MIG if you have a lot of experience and get everything real clean. Majority of people I've seen starting with MIG though use wrong current and too high wire feed so would be better off using JB Weld as the 'weld' is just laying on the surface and can be peeled off pretty easy. Main advantage of TIG is localised heat so less distortion
Best thing I ever overheard
Brian Morgan, 1982
Online irk miller
« Reply #6 on: Jul 23, 2017, 00:30:46 »
I've welded and modified at least a dozen tanks with MIG.  None of them leak.  It's not impossible, but it's much harder to do with MIG.  At the time I got the MIG, TIG prices were still through the roof.  They've come down significantly since then.
Offline datadavid
« Reply #7 on: Jul 23, 2017, 17:11:12 »
Yes, i have a very hard time welding thin sheet 100% air tight with the mig, its just not the best procedure for it. Short hot beads with very little feed is the trick for me at least.
Online irk miller
Welding Gas Tanks
« Reply #8 on: Jul 23, 2017, 17:18:05 »
Yep. Literally a thousand little tacks in rows. Then check with bright light. About a hundred tacks to fill the missed holes. Check with light again. About 10 more tacks to fill more holes. LOL. Check with light again. Jap tanks are the worst for sheet gauge. It's far from ideal. At the time I got my MIG, it was $600 for a good Hobart that could run off 120v/20amp service. A good TIG was $1500 plus and iirc there wasn't a 120v option. I still MIG and oxy/acet most sheet. TIG is still in my dreams.
Offline Hurco550
« Reply #9 on: Jul 23, 2017, 21:35:05 »
Your right Eric, tig prices have dropped crazy amounts in the last handful of years.  $1400 will now get you a ready to go Lincoln square wave 200 ac/DC (aka aluminum and steel) inverter with 120v and 220v capability. About $600 will get you a Chinese everlasting DC (steel only) tig that in my experience is more than adequate for us garage builders, if you can do without aluminum capability.
Sent from my SM-G900V using Tapatalk
~ bradj
1973 Ironhead Hardtail: http://www.dotheton.com/forum/index.php?topic=68135.msg788081#msg788081
"much ingenuity with a little money is more profitable and amusing than much money without ingenuity" - Arnold Bennett
