www.Moto-Madness.com
Author Topic: Chrome exhaust cleaning  (Read 986 times)
Offline Mr Bernzo
« on: Sep 12, 2017, 22:19:21 »
I have been using every available method I can find to clean this set of chrome pipes. I assume the stains are 2 stroke gearbox oil baked onto the chrome. The clean up of dirt, grime and rust has not been to hard to do, these stains are stubborn though.
And ideas would be appreciated.
I have tried chrome cleaner, glass cleaner, aluminium foil, steel wool, metal polish and CLR clear so far.
Sent from my Moto G Play using Tapatalk
Smell that? 2 stroke...
1978 Suzuki GT185, 2012 Husky TE449, 2003 Suzuki SV1000
Offline esmoojee
Re: Chrome exhaust cleaning
« Reply #1 on: Sep 12, 2017, 23:09:09 »
Pick up some Quick-glo, I promise you wonít be sorry.  That stuff works like a charm!
Offline esmoojee
« Reply #2 on: Sep 12, 2017, 23:11:00 »
Quick glo!!!!
« Reply #3 on: Sep 12, 2017, 23:35:41 »
Easy-Off oven cleaner.
"Remember when Goldwings were sexy? Me neither" -- Comet Tavern bathroom, Seattle.
Offline Mr Bernzo
« Reply #4 on: Sep 13, 2017, 07:54:02 »
Quick glo!!!!
Will give it a try, looks like it's available where I brought my paint from.
Offline Mr Bernzo
« Reply #5 on: Sep 13, 2017, 07:55:41 »
Oven cleaner you say? Might even have some of that in the house.
Offline WhyNot
  • ~~~If it ain't raining, I'm riding~~{iii}?~~prost~
« Reply #6 on: Sep 13, 2017, 08:10:19 »
You can try scratch and swirl remover, the stuff harley davidson sells works quite well.
2006 Harley Davidson Heritage Softail
1975 Honda CB750K5 needs carb work
1974 Honda CB350F2 needs tins painted (being lazy)
1972 Honda CB175K2 roller no engine
1972 Honda CB/CL350 Engines need roller
1972 Honda SL350K2 Frame for above engine
1972 Honda CB100K2 needs kicker shaft
1990 Mitsubishi MM needs engine rebuild
1984 Dodge D50 Beater DD since 1997
Offline esmoojee
« Reply #7 on: Sep 13, 2017, 09:07:26 »
The thing about the quick glo is that it has a wax in it that helps form a protective thin coat.  Just something to consider.
« Reply #8 on: Sep 13, 2017, 11:04:14 »
Best stuff for oil that's been burned on. Let it sit for a minute or two and that stuff will wipe off. Won't damage the chrome.
Offline esmoojee
« Reply #9 on: Sep 13, 2017, 20:14:43 »
If you do use oven cleaner I would spray it on a rag not directly on the pipes. You could get over spray and you donít want it sitting on the aluminum block too long. It can cause pitting.
