3RM: Rust Revival / Retro Moto Collaboration Build
Sonreir said:
No such troubles on the 360. There's enough slop that they'll swap right out.
Glad to hear it!
Figured it was worth mentioning regardless ;D
Basement cleanup on the lower case tonight. Two dips in the degreaser and a nice pressure washer bath does wonders.
Got the bottom end all buttoned up and flipped the motor over for the top. Got the top peeled back and everything looked good until I flipped the head cover over. One of the journals looks like an angry girlfriend has been in there gouging it with a screw driver. The other 3 look acceptable and the cam shaft seems to be fine? I went ahead and tore the top end down on the 3rd motor I just recently acquired and sure enough, same damn thing on a different journal? Is this common?
probably a sticking valve, letting the rocker arm slam down on the cam lobe, good news is they were all the same part, so they're swappable any one of the 4 to any other
Not oil starvation. That would look like solid lines running across the face of the follower.
Junior over at Retro Moto was absolutely up to no good last night. Check this exhaust out! We talked about this idea for quite a while and it's awesome to see it coming together so well. In the end, the exhaust will port out the left/right sides of the tail section.
Harness in progress!
Nah Justin. I guess we outta get started on it. Trek, the pipes are wide open and louder that the paint job on your motor!
