Tune-A-Fish
BOTM LOSER Proudly Deplorable
One would think before spending on paint and bling you should make er sing? Fast and loud is way cooler than pretty and dead. roo num one gasshopper... make it run first!
Tune-A-Fish said:One would think before spending on paint and bling you should make er sing? Fast and loud is way cooler than pretty and dead. roo num one gasshopper... make it run first!
catsy said:Already runs! earlier in the thread theres a link to her first start in years, i knew to tick that box after being on this forum
adventurco said:Coming along nice mate. What xb said about the cardboard oven works well. I used a cardboard box lined w/ aluminum foil and pointed a heat gun through a hole in the side. Got quite hot, over 350 degrees and that was with a cheap $20 heat gun.
I might look for one of these for a next project ;D ;D
Tune-A-Fish said:Don't do that in the house man
adventurco said:Heh. I did it in my workshop but kept an eye on it. Just be careful the heat gun doesn't contact the cardboard and you should be good to go
deviant said:What year is that bottom end out of? 76 and later had the better gear ratio and 42 teeth sprockets. Case and covers were unchanged, though.
