Yes and I bought a kit from China with it ignition tank lock and seat lock I wired it in have power to everything but the start button someone told me it a motorcycle shop that the Chinese ignitions have no resistance so therefore they don't work kind of makes sense so I'm looking for an oem ignition now problem is I have to get the plugs to go with it one from the harness when from ignition turning into a real nightmare about ready to just buy that bypass off of eBay to have no ignition switch. Yes I do keep the bike in my living room now I don't trust my friends garages anymoreSonreir said:What problems are you having? I'm assuming the wires were just cut from the switch?
2006. I just got an O.E.M. Ignition in the mail. Ill wire it in tonight after work and see what happens. Thanks1fasgsxr said:What year ?
Where? I hav' nt had much luck finding diagrams online. Especially where ignition are concerned.teazer said:I think he said that the starter button isn't working. Wiring on those is a little complicated compared to our old simple bikes, but there may be damage to the right bar switch or to the clutch lever or side stand switches which cut power to the starter button.
If he opens up the right switch and with bike in neutral and side stand down, he should have power to the red/black side of the starter button. If not, start at the clutch lever switch. The wires may have come off. The power comes from the run-off switch and if that has power, check the solenoid connections.
Wiring diagrams are available on line if he doesn't have a workshop manual. That would be a good place to start...
I will try all of this and get back to you later today. Thank you for your time.Turtlejen said:Where? I hav' nt had much luck finding diagrams online. Especially where ignition are concerned.
Sent from my LG-H901 using Tapatalk
