Engine braking won't damage your engine...unless you're riding a two-stroke running premix. Even running a lube system I'm not overly fond of sustained engine braking on a two stroke. In fact, engine braking is a crucial part of breaking in an engine. Check out
this guys take on running in a bike, I reckon it makes a lot of sense.
Anywho, the whole deal with more front than rear and no front in corners is exactly right. Only one thing kinda stuck out for me:
Of course, if you anticipate a corner, and are in the proper gear, you shouldn't really need to brake at all
Thats right, because you will have done the braking beforehand and will have downchanged to the gear you want to
accelerate out of the corner in.
Braking is, however, an integral part of coming up to a corner. I won't pretent that I ride to the speed limit. I ride to the conditions. Sometimes this means I might actually be going
slower than the posted limit. You should accelerate through and away from a corner and start slowing down (braking) before the next corner. Linked turns will see a more constant speed or more aggressive lean angle being used, as you can't brake as effectively.
Lastly, Nanahan Man gets the prize for best post IMO:
You squeeze the front brake lever ... have your entrance speed sorted out BEFORE getting into a corner ... You may be surprised at how fast you can [stop].
Right on, especially that last bit. I like practicing emergency stops, I've had to use them a few times when car drivers have done stupid/dangerous things (usually involving them not seeing me and me having to stop to avoid hitting them). Work out how long it'll take you to stop from higher speeds, to, as this will give you a benchmark for big ticket hazards ('Can I stop/slow/turn in time?'). I've worked out that I can stop in ~100ft from 75mph, using just a bit more than moderate braking force. Only other thing I'd add is hazard anticipation and buffering. Look ahead for hazards, as well as potential ones. Buffer away from these hazards by controlling the space in front of your bike and your position in the lane (left, middle, right).
Thats all folks, keep it up! - boingk
