Re: '74 CB360 cafe/fighter-ish project - adventures in tuning
Been riding a lot this week, mainly because I don't have another means of conveyance. Its been in the high 60's-70's most the week. As you've seen from the pics I have big k&n filters and straight pipes that are a couple inches longer than stock. I'm using a 115 main jet and running PJ's secret spec air jet to lean out the mid range. It pulled great on the mid range and top end but would sputter and miss while cruising and was really bad while deccelerating. Low end was missing too. The bike starts on the first kick without any choke and the problems get worse as the engine gets hotter, so I figured it was a rich problem. I raised the float height 1mm to 19.5mm (PJ's recommendation) and adjusted the pilot jets to 1-1/2 turns out, then equalized the exhaust pressure (left cylinder needed to be adjusted out another 1/4 turn). The problems dramatically decreased, mid range and top end power was up too. Problems still showed up when the bike warmed up, though not to the extent. Today I swapped out the 115 main jets for 110's and equalized the exhaust pressures via the idle jet screws (ended up at the same number of turns). It was in the 50's today and the bike still popped, only every so often, at cruise. Barely misses on decceleration when engine braking now, only once or twice on the whole ride (about an hour). At cruize it still popped and missed a little, but less than it did before the jet change. Kinda felt like mid range and top end power was slightly down, but I'm not too sure. I would say its livable right now, but I'm going to sync the carbs with a manometer. Gatta find one first though.
...the saga continues.
Sent from my T-Mobile G2 using Tapatalk
