alex2445
Ok so I brought my fourwheeler into lab to fix some stuff on it.
Clean up plastics
Fix idling problem
Clean off rust and repaint
Replace rear tires
Replace steering bearing
Forgot to get pics from the very beginning
There's rust and paint missing on top of the frame, and the exhaust needs cleaned and painted
Got the carb off, but after I cleaned it I ended up screwing it up, because I wound the choke place shaft the wrong way and screwed up the spring, so now I have a senior who might buy it and use it for his project.
Rear rack is cleaned off, you can probably see how it's bent and I fixed that. now it's been primered and soon will be painted
The top if the frame is cleaned and primered. I painted it but have no pics of it.
The engine was shaking really bad so I was gonna get new mounts till I discovered the top mount was missing a bolt and now that's been replaced and it should be fine. I'll have more pics on Monday
Clean up plastics
Fix idling problem
Replace rear tires
