Nebr_Rex said:Those are the same as the late KZ750 pistons. Taller dome and thinner rings than the
earlier piston.
Roc City Cafe said:what year qualifies as "late" I looked at some and got a little giddy for building an 850something with the stock 750 motor that's being replaced by the fran-kz-stein 900
Nebr_Rex said:Yes
Doesn't the sohc 750 have an offset exhaust valve?
Nebr_Rex said:Yes
grcamna5 said:Yes, I will do that Rex & list the dimensions here..,after the Holidays.
Thanks
grcamna5 said:I'll get over to storage and get a hold of those pistons;I only have a US inch calipers for now and hope that'll be OK to use.I'll be back w/ those dimensions after a while..
grcamna5 said:I then measured the piston from the shoulder-top edge of the crown down to the upper edge of the wrist pin hole and it measured .644 in.
xb33bsa said:no you are just not dealing with reality
10.5-1 with 87 would probably need to be ignition too retarded and lose power
the math involves careful measurements using liquids and clay, making measurement in a dummied together motor, there is no other way to do it
and really each chamber should be done with a matching piston
as well you need to get the squish clearance very precise in a 10.5-1 , patience and knowledge a lathe and experience using one
good luck with it there is plenty of info available online about cc'ing, squish bands and CR"s ..the math part is very easy a 7th grader could do it the measurements are pretty easy as well just need to be carefully done
all this when you can buy them for under 300
