mydlyfkryzis
当有疑问时踢你的敌人在生殖器上,你可以道歉后
Mine still has 165 PSI. When I bought it in 1979, it had 700 miles on it. Compression was good. Used Regular 87 gas....
Honda recommends 86 Octane PON
Honda CB360 Owners Manual:
Use 91 Research Octane (RON) or Pump Octane (PON, How it is sold today) of 86 or higher. I have always ran regular 87 in mine.
CB350 is the same compression PSI, same RON recommendation. When the country switched over to PON from RON, I used 87 in my CB350 (back in the 70's) without issues.
My Older Honda's never pinged or knocked on 87 PON.
My 1991 Nighthawk 750 has a compression PSI of 142-199 PSI...Also uses regular 87 Octane.
No reason an engine with 170 PSI compression needs anything but regular gas.....You can put 91 in, it won't hurt....but is just extra $$ to the oil companies.
