Depends on what your controls are like. Some are routed externally through the bottom of the control. Others are internal, through a hole drilled in the stock bar. With clip-ons, it's pretty easy to route your wiring through the bar if that's what kind of controls you have. Pretty self explanatory, drill a hole in the bar where the wiring will thread through, but make sure you file or sand the hole as simply drilling it will leave sharp edges that will tear up your wiring. IF you have internal wiring on your controls but want to run it externally, you can just notch the underside of the control and run it that way.
