CB750K Mainely a Dream
Maineiac
Well, she's all done, just in time for summer ;) There's a build thread in the projects for those interested, but it's mostly just pictures.
Mainely A Dream
1972 CB750K2
Engine:
Rebuilt with all new gaskets & seals
836cc Wiseco Big Bore Kit
Web Grind Cam
New valve springs
New tappets
Stainless hardware kit
Mikuni RS34 Flatslide Carbs
Dynoman pod filters
New carb isolators & clamps
Yoshi style 4 into 1 exhaust
New Motion Pro throttle cables
Dyna 2K Electronic Ignition
Cycle-X points cover
Dyna 3 ohm coils (w/resistors)
New plug wires/NGK iridium plugs
New Motion Pro clutch cable
Custom oil tank & lines
Frame:
Eastwood Chassis Black 2K ceramic paint in Satin
Shaved mounting tabs
Removed center stand & bracket
Gusseted and smoothed
Welded kick-up tail section
Bronze swingarm bushings
Tapered steering bearings
Dresda style boxed swingarm
New lower shock bushings
Cycle-X billet triple trees
Tarozzi modified clip-ons
Gauges/Electrical/Lights:
Rewired bow to stern
Custom electrics box
Rick's solid state reg./rect.
Earth-X Lithium Battery
5-3/4" Bates Halogen Headlight
Joker Machine Taillight
Acewell digital tach./speedo.
Innovate Wideband O2
External oil pressure gauge
New start solenoid & fuse block
Suspension:
New Cycle-X early style forks
New fork caps
T-Kat fork brace w/satin powder
New fork seals & gaiters
Slightly polished fork lowers
Progressive fork springs
Hagon Slimline rear shocks
Brakes:
Dual disks lightened &drilled
New Tracker style master cylinder
New stainless lines & alloy tubing
New stainless caliper pistons & seal
New EBC brake pads
New bleed valves & caps
Calipers powdered satin
Wheels:
Excel front 1.85"x19" alloy rim
Excel rear 2.25"x18" alloy rim
New tubes & rim strips (duh)
New wheel bearings
Powdered satin spokes
Avon Roadrider tires 3.25"/4.00"
Slightly polished hubs front & rear
Bodywork & Upholstery:
'78 Supersport Tank
Muscle Car hood pin gas cap
House of Kolor Maroon Metallic
Eastwood Satin Black 2K accents
Custom seat & pan
There's still some gloss pin striping to do and gloss letter faces, but otherwise, she's pretty well sorted out.
I'll give a shout out to VastMoto, Metric Motorbike, and Maine Moped Factory for their continued support and influence. Also, Mike Rieck of JMR Cylinder Head Porting, for building a supremely strong motor for me.
I just may be able to do that. We will be rinding through Maine to and from NH and was thinking of swinging by Scott's shop. Will be in North conway from May 11-14th and may make a trip into Portland or may ride home through there on the 14th.
Cool, Fishing? Or Freight? Or Tug? Whatever way be safe on the water and I am sure I will be riding through Maine again this summer.
If anyone wants to follow, I'm doing a rebuild over on the sohc forums with a gixxer frontend:
http://forums.sohc4.net/index.php?topic=131294
Re: CB750K Mainely a Dream
That's real clean. Interested to see how it turns out with the Gixxer front end.
How do you like that Acewell gauge? I've ordered some mini gauge for mine, but looking into it for later. Seems like it pretty does everything in one.
It's pretty snazzy for the price! Have to pay real close attention to how it's mounted, as the angle of view will wash the LCD out if not spot on. Otherwise, it's dope.
