Hi,
Long time lurker, first time poster. I'm running into a problem that I just can't get past.
After a recent top end rebuild due to oil starvation, I'm unable to shift the bike higher than first gear. At first I thought it was due to the shift lever linkage, so I replaced the original shift lever with a simple one that attaches directly to the shift spindle. Although it removed the slop in the lever, it didn't allow shifting out of first. So, I tore open the right side, removed the clutch basket, etc to take a look at the stopper and the drum cam that can come loose according to other posts I've read. Everything was secure and I was easily able to shift through the gears by turning the screw on the top of the star-shaped drum cam. So, while I was in there, I took the mechanism apart and gave everything a thorough cleaning and reassembled. At this point I was also able to shift through all gears using the shifter and rotating the rear wheel. So, problem solved, I thought.
After buttoning everything up on the right side, I gave shifting a try, and I was back to being stuck between neutral and first. After drying my tears of frustration, I removed the side cover; tried the lever and was able to move through the gears. Put the side cover back on and just finger tightened the bolts - still success! Torqued down the bolts - problem came back. So, it looks like something is binding the shifting mechanism behind the clutch basket.
I have noticed that there is approx. 3mm of lateral play in the spindle shaft. In other words, from the left side of the bike, I can move the shaft in and out a few mm. which can mess up it's alignment with the drum. However, from looking at the parts fiche, there doesn't seem to be anything that actually keeps the spindle shaft in place other than the pressure from right side cover.
I hope I've described this adequately. Thanks for your help.
Steve
Steve
