KZ 440 timing
YoungMoneyyy
Hey guys,
My engine has been sitting on the garage floor since sept, so I finally did the head gasket on my '81 KZ440... problem is I think I totally fuckered up my timing in the process, as I was putting it all back together I had this stroke of brilliance, "probably shoulda set it to TDC before I tore it apart" damn! So here I am trying to get the timing sorted out and realize I'm in way over my head, any pointers for a newb?!
Sent from my SM-G928V using DO THE TON mobile app
the cams need to be put back in correctly or your timing will be off and you have the potential for the valves to hit the pistons. This is from a kz400 manual but i think it is similar for the 440. you can get the FSM for the 440 here> http://kz400.com/WorkshopManFrameset-5.html
