andrew
a few weeks ago i bought a partial basket case from a friend of a friend. i got the 72 frame and motor, late model forks and triple tree, axles, wiring harness, carbs and a bucket full of random hardware.
got it home and started cutting it in half. i ordered up a hardtail section from TCbros, when that showed up i took the front frame half and the tail section to my buddies shop to mate the two.
first test fit/mock up.
as you can see, even though these hardtails are designed to fit early and late frames, they def. dont fit the early frames very good at all.
we ended up having to heat the rear lower rails to bend the entire seat rail area down to meet the stock back bone. and another issue we ran into was the slug to meet the upright frame piece to the bottom rail of the hardtail was completely too small. good thing my buddy own a hot rod shop and has every tool and lathe at his disposal. we had to machine and make a completley new slug that was wider and longer than the one supplied in the kit. not a big deal, just more time.
finished up the frame in time for the iron maiden concert that night. started cutting off all the unnessesary tabs and mounts on the frame.
after i finished the frame i had to address the late model forks/triple trees on the early frame, as the late model lower triple clamp has a longer steerer stem. my first thought was to find someone who could tap the stem down another 3/4 -1". after a few calls, i soon found out no one had a tap that big nor in that size. called up a local chopper shop and talked to the guy and he said he had an idea. drove out to his shop and had him throw it on a lathe to remove the factory weld on the bottom of the lower clamp and then pressed it down 3/4 of an inch and then rewelded it back in place. problem solved. late model front end on an early frame with out stacking a bunch of lock nuts or washers to compensate for the height difference. to me, that would just look hokey and half assed.
still have to have my biltwell solo seat pivot welded to the back bone and the spring mounts welded to the cross section of the frame and then i can blast it and paint up the frame. but that will be a ways down the road, as i still need to do a bunch of mock up and mount tabs for the mid controls, chain tensioner, battery box, etc.
