Engine paint
Odontologist
Umina Beach, Australia....Where does that part go?
I painted my cx500 engine with VHT primer and enamel...3 coats each, followed by 1 hour oven cure at just under 100 celcius.
I was then adviced to powdercoat if engine stripped. It was but now too late and deed is done.
I was told that paint tin can job wont last. I have no experience with this.
Anyone care to give their 2 cents worth?
Sent from my SM-G930F using DO THE TON mobile app
I like paint....easy touch up. Actually I'm lazy and don't mind a bike that looks ridden....judt not rusty/junky.
I had mine dipped and anodised. Only
Down side is is easily Damaged or scored
VHT is solid.
Try not to let gas sit on it, but road grime oil etc will be no issue.
A gas spill here and there isn't going to destroy it either, but if you have a carb leaking and it sits for a few days it will make a mess.
In my experience at least.
