DO THE TON
Blood Sweat Tears and Grease => Projects => Cafe Racers => Topic started by: cbinvb on Oct 03, 2016, 13:31:13
Title: Honda SL200 Mini
Post by: cbinvb on Oct 03, 2016, 13:31:13
SL125 frame
(http://i.imgur.com/WltjN93.jpg)
The SL100/125s are pretty cool imo
330mm shock, 700mm front forks, 16 inch rims
CB160 swingarm to get a little more length over stock
(http://i.imgur.com/boiIFVM.jpg)
Not crazy about the mags
Found these 3.00x14 spoke rims on aliexpress
(http://i.imgur.com/O0R8V3E.jpg)
(http://i.imgur.com/W3OEHpw.jpg)
I went with 120/80-14s front and rear
The front end is from some pit bike
(http://i.imgur.com/759YRyl.jpg)
(http://i.imgur.com/exOQy5l.jpg)
(http://i.imgur.com/Cx1ZDcb.jpg)
An ebay'd xr200 motor can drop into this for a 220lb bike; need something capable for stints on the highway
Here it is in the middle of tear down and inspection, for new top end, beefier clutch plates/springs, and modern oil pump
glad I did, because whoever had this motor before me didn't know how to tighten the cam chain so it chewed into the cylinder
and washed the whole thing in metal shavings.
And oil spinners work really well.
(http://i.imgur.com/hqqHwio.jpg)
(http://i.imgur.com/HW5CJDN.jpg)
-1.5" on the seat
(http://i.imgur.com/Gk509UN.jpg)
since it was originally drum brake, I will sort something for the rear disc conversion
(http://i.imgur.com/XAxECb1.jpg)
(http://i.imgur.com/NPaI3i6.jpg)
(http://i.imgur.com/EbVl4e6.jpg)
Por-15 on an old seat pan
(http://i.imgur.com/p5Ei22k.jpg)
Thanks
Title: Re: Mean Green SL100 Mini Bomber
Post by: alemonkey on Oct 03, 2016, 21:06:37
Very cool little project.  My first "bike" was a little 50cc Honda.  My dad still has it out at the farm and my nephews ride it.
Post by: ridesolo on Oct 03, 2016, 21:53:01
Wow, I'm liking this one!
Post by: cbinvb on Oct 05, 2016, 22:36:40
I got a few more bits to move ahead with
motor is starting to come together.  Finally got the machine work done and back.  High comp piston, new cam and new valves
(http://i.imgur.com/49Wi9tl.jpg)
(http://i.imgur.com/fpmV38J.jpg)
(http://i.imgur.com/fs1zeds.jpg)
little battery to keep the lights on.
(http://i.imgur.com/YuJXrka.jpg)
Post by: cbinvb on Oct 23, 2016, 04:03:20
- reamed the axle tube to accept a 14mm axle, which is what this cb175 swinger needs to work with my frame
- found some shocks
- finished the motor and fitting/bracketing
- tryin out the exhast
(http://i.imgur.com/invkQxX.jpg)
(http://i.imgur.com/azyhtQU.jpg)
(http://i.imgur.com/r8DHLvq.jpg)
(http://i.imgur.com/1G4DZpZ.jpg)
I think I like the low straight the best.
(http://i.imgur.com/uQxp4Nn.jpg)
(http://i.imgur.com/5YFoBBE.jpg)
Post by: cbinvb on Dec 05, 2016, 18:41:05
I have made a little bit of progress on this build.
Have all the wheel spacers made and the front and rear brake hangers fabbed as I am going with Brembo 84mm crabs instead of the KTM calipers I originally had.  This means I had to switch out for larger brake rotors becuase the crabs hit the spokes on the wheel with the smaller rotor diameter.
Time for paint
(http://i.imgur.com/SZrBiY1.jpg)
(http://i.imgur.com/TsRvWux.jpg)
(http://i.imgur.com/WprTqQo.jpg)
https://www.youtube.com/watch?v=oileggceBEs (https://www.youtube.com/watch?v=oileggceBEs)
Post by: Luugo86 on Dec 05, 2016, 18:57:15
 Looks good man. I was wondering who did your cylinder head/cylinder work ? I am building an SL175 at the moment and need the head redone and the jugs honed
Post by: Maritime on Dec 05, 2016, 19:41:15
Holy shit, I like this little beast.  Good job so far!
Post by: cbinvb on Dec 05, 2016, 19:54:24
So there's a little place in North Baltimore that did my work.  https://goo.gl/maps/z9RXWstnaAA2
Otherwise you could call up Powroll and Jerry will let you know what's what. https://goo.gl/maps/UMEyts9cQao
Thanks, its real slow going during the semester but winter break is coming up in Jan so I try to finish it then.
Post by: cxman on Dec 05, 2016, 20:01:08
i have not been able to get a answer at powroll for a few weeks or a call back i have been trying to get some stuff from them
has any one actually talked to them if so how do i get them?
Post by: Luugo86 on Dec 06, 2016, 11:07:45
Thanks for the info man. I'm in central PA so blatimore is very doable.
Post by: cbinvb on Dec 07, 2016, 01:29:52
I dunno bud, I havent spoken to him in months but that number from Maps is the one I called.
Post by: Luugo86 on Dec 08, 2016, 12:24:34
  Hey bud, one more question, did that little place you had your machine work done on your head and cylinders.. did they also rebuild the head for you or just do the machine work? Thanks again man.
Post by: JustinLonghorn on Dec 09, 2016, 10:20:17
Rad little scoot.
Are you in the B-more area?
Post by: cbinvb on Dec 11, 2016, 23:17:10
Hey.  Yea, I brought him everything disassembled but with new valves and seals.  I asked him to recut the valves seats and bore the cylinder to match the piston i handed to him.  He gave me everything back assembled and I put the new top-end on at home.
Rad little scoot.
Thanks Bud, yes I am.  I go to UMBC
Title: Re: Green SL200 Mini
Post by: cbinvb on Apr 21, 2017, 05:05:08
Hey all, here's a little update on the mid size.
Its coming along slowly but most of the worst is done.
- everything thats getting PC'ed is done
- electrics are all sorted, fingers crossed
- motor is rebuilt, painted, wired
- front end is coming together
- instruments and controls look good
Mostly just need bracket fab, paint tank and finish seat, cables, and tuning.  Not small things, but now that the weather is nicer i can spend more time in the garage
Post by: JustinLonghorn on Apr 21, 2017, 08:57:25
Rad.
Post by: coyote13 on Apr 21, 2017, 11:40:14
Very rad.
Post by: cbrianroll on Apr 21, 2017, 12:59:36
I'll third that....very, very rad.
Post by: Luugo86 on Apr 21, 2017, 15:44:49
Very cool.
Post by: Luugo86 on Apr 21, 2017, 17:10:03
What front end do you have on that little scamp?
Post by: cbinvb on Apr 25, 2017, 03:13:28
Thanks guys.
Those forks are marzocchi clones from china, about 27in long with 4-5in of travel.
Post by: cbinvb on May 09, 2017, 22:46:53
Starting to get down to the last few bits.
Tank is painted, I went with red (pics next time)
Seat is nearing completion (anyone know a good upholsterer in the B'more/DC area?)
Rear wheel aligned and spaced and calipered
Wiring in and mostly hooked up
I am 6'1" so here's a few pics for scale
