www.Moto-Madness.com
Author Topic: EGLI frame, TR1 engine, build from scratch  (Read 69810 times)
Offline 50gary
  • Under the Limelight
Re: EGLI frame, TR1 engine, build from scratch
« Reply #30 on: Jan 13, 2012, 23:24:44 »
In reply #12, 5th picture showing the detail of the joining of the two different tubes.  I would have cut a radius (I believe it's 2" 4" diameter?) on the end of the large tube and formed it so the radius would contact the small head tube in a semi-circle.   Probably would have to be heated then weld it to the head tube.  Viewed from overhead the large diameter tube would taper from the 4" dia. to the width of the diameter of the head tube.  This would eliminate the flat end piece made up of the "chord and arc."   Total less inches welded and a simple design?  I'm mean this as shop talk over a pint of beer not in any way critical, as I mentioned I thought your way was the way Egli had done it but I wasn't sure.
  I like your additional head tube brace, I'm doing an Aermacchi 250 replica and will use virtually the same method.  Keep up the good work, excellent and interesting to boot.    This is why this forum is enjoyable for me.
  Cheers, 50gary
« Last Edit: Jan 13, 2012, 23:38:44 by 50gary »
Short track speedskating, cycling, guitars, motorcycles, juggling dynamite. I was born to laugh at Tornadoes.
Offline 1969Honda
« Reply #31 on: Jan 14, 2012, 00:15:27 »
I'm interested to see how you're going to make your rake and swing arm angles adjustable, are you going to use something similar to an eccentric cam or offset bearing cups? ??? Do tell, I used to work for a small mechanical design firm (I'm no engineer) and enjoyed seeing/assembling the creative ways people would come up with these solutions.  I still try to do a little in SW every now and again but it's definatly a skill you lose with time if not practiced.
BTW I'm seriously jealous of your facilities and your welder's skills, makes me miss working at the M.E.shop. What was your address again.... I think I have some leave coming up and I know a few guys that are into the whole clandestine thing, just need a truck, a.... oh.... did I say that out loud.... ;D
"Life happens, you'll either get over it or die from it"
Offline loekm
  • TR1 racer is starting to look like a bike!
« Reply #32 on: Jan 17, 2012, 17:03:57 »
Hey people,
Spent the evening machining some parts for the bike again. Ajustable swingarm is ready (in parts). Just a short picture update :)
Excentric for swingarm:
Pieces needed to assemble the swingarm:
Swingarm axle partly assembled:
All the parts in the frame as mockup:
Back position:
Front position:
The mechanism has 24mm of ajustabillity :) I'm happy ;D and I'll see if it works and is needed in the end...
@50Gary:
I think your solution for the steeringhead will work as well... I didn't think about it your way, it saves some welding wich is good beacause of less heat input, but maybe it brings more "tension" in the large diameter tube because the tube is deformed before welding. My experience tells me that deformed material (heated or not) will release it's tension after welding and maybe that will deform the construction of the steering head during or after welding... who will tell.
It's very nice to have discussions like this for sure! All our bikes get better because of this :)
@1969honda:
I hope this makes clear how the swingarm thingy works. The steering head is somthing different. When it needs changing the angle I have to machine new aluminium inserts... Not a fast job but it is possible and better than grinding and welding the steeringhead again.
Enjoy the evening!
Best regards,
Loek
Offline Greg-NWO
« Reply #33 on: Jan 17, 2012, 19:32:27 »
So cool, these are the types of threads I spend a lot of time scouring the net for :D
Really nice shop and very cool build.  Keep the pics coming :)
Offline 1969Honda
« Reply #34 on: Jan 17, 2012, 20:30:41 »
That's exactly what I had in my head when you mentioned the adjustable angle! Are you going to be welding some type of a clamping mechanism on the back of the swing arm boss around the cut outs to hold the position of the eccentric cam? Or is there more mystery to the puzzle? splines to index off of? maybe a key way?
Offline loekm
« Reply #35 on: Jan 18, 2012, 02:56:58 »
Good morning all,
@honda1969:
Yes... Two pieces of tube, welded at the back will deliver the clamp system, and some sort of indexing is on the way... it'll be a simple stripe I guess. And a tool like the one from an angle grinder (two simple holes in the aluminium part) will do the ajustment. So no special tricks to be expected there :D
@Greg-NWO:
Thanks! i'll keep the pics coming for sure!
Now to work :)
Best regards,
Loek
Offline loekm
« Reply #36 on: Jan 20, 2012, 12:47:02 »
Hey people,
Short update with some pics.
Front sprocket fits! (XS650 sprocket final ratio 18/38):
Frame back in jig:
Start of mountingpoit rear cilinder:
Mountingpoint of rear cilinder in pieces:
And it goes together:
And last, insert for stearinghead:
That was last night's progression, to be continued!
Enjoy your weekend!
Best regards,
Loek
Offline CrescentSon
« Reply #37 on: Jan 21, 2012, 14:13:14 »
Can we stick to simple stuff like particle physics and string theory. This beast is making my head hurt. Amazing results so far Loek.
"I hated hipsters before it was cool." -Sonreier
"Lifes a bitch when your trying to sell gold bars to beggars" -VonYinzer
"To say that ALL cafe racers are the same degree of ho hum is like saying that finger banging a fisher price piano is on par with listening to Beethoven." -Kanticoy
Offline dcmspikes
« Reply #38 on: Jan 21, 2012, 14:16:05 »
yeah im on board for this one.   keep it coming
Offline pacomotorstuff
« Reply #39 on: Jan 22, 2012, 15:59:58 »
Leokm,
I went the same route as you for the sprocket - XS650Direct in Canada is the MikesXS distributor, but I used the optional 520 sprocket.
I don't see any capture method on your countershaft sprocket - are you just going to modify the locking plate like I did (I posted photos on one of the other XV920RH / TR1 threads on the DTT site) or???
I was looking at one of my friend's son's KTM MX bikes and all they use is an external Circlip - simplicity itself!  I went through an industrial supplier's catalogue and found one the correct size to fit the XV / TR countershaft - just haven't gotten around to buying one yet and trying it out.
Let me know about your locking mechanism.
Love your frame - you're building the bike Yamaha should have.
Regards,
Pat Cowan,
Vintage Motorcycle Fiberglass
