Re: 71 Indignant CB175 - Almost A Roller!
Well its been a busy weekend. Lots of pictures in this update!
I got my "dampeners", or sprocket bushings, in and quickly realized that I had to do more work on the hub to get the new ones in. When I drilled out the old ones, I never got the outside metal sleeve out. So I had to do that and it was a PITA! I tried the dremel, the drill, and finally figured out a way to chisel a groove in the metal and pull them out with pliers.
I also did some final finishing touches on the seat mold in preparation for the fiberglass.
Saturday afternoon I started the first layer of fiberglass. I cut out a rough shape out of CSM and proceeded to mix the resin. Unfortunately, I was not aware that acetone eats plastic. So when I tried to dilute my mixture to give me more working time, the acetone ate through my Solo cup and made a mess. So the first layer didn't get an accurate mixture on it, and after a hour and it hadn't hardened up, I had to mix some hardener and acetone and paint it on. That worked for the most part.
I also found a nice guy named Dan to stop by and help me true up the wheels that I had reassembled.
On Sunday, Dan came back over and we finished the wheels, and I put another layer of fiberglass on the seat.
After the seat cured, I cut it out and did a partial assembly on the bike to see how it all looks. The seat will sit a bit lower and the tank needs raised up and adjusted, because its not sitting right in the mounts, but otherwise its just what I had imagined. Enjoy!
Thanks for looking!
