www.Moto-Madness.com
Author Topic: CB360 project  (Read 27565 times)
Offline thrillseeker
Re: CB360 project
« Reply #160 on: Mar 25, 2017, 19:21:31 »
Don't you need to heat them up (flame on) and anneal them prior to installation?
Yes that's recommended
Don't take life too seriously, you'll never get out alive.
Offline redwillissuperman
  • Keep it simple- engine, wheels, bars
Re: CB360 project
« Reply #161 on: Mar 25, 2017, 19:22:44 »
Getting "dead soft" is key. Did you do standard thickness or drop it down a tenth?
Offline irk miller
Re: CB360 project
« Reply #162 on: Mar 25, 2017, 20:04:41 »
Lani will tell you straight up to heat them to red hot then dunk them in cold water.  Annealing them is key to them working.  Also, spray both sides with copper gasket.
CB360 project
« Reply #163 on: Mar 25, 2017, 21:07:14 »
I did. The deck needs milled. My machinist is taking care of it.
« Last Edit: Mar 25, 2017, 21:10:48 by thrillseeker »
Re: CB360 project
« Reply #164 on: Mar 25, 2017, 21:09:16 »
Offline trek97
Re: CB360 project
« Reply #165 on: Mar 25, 2017, 21:30:51 »
Note to myself...Never put a straight edge on my 360s head!   ::)
Re: CB360 project
« Reply #167 on: Mar 25, 2017, 22:18:21 »
I was able to get 0.0015 feeler gauge through there. My machinist said if I can get more than 0.001 it probably should be fixed. If I were using a composite gasket it would probably be fine. No worries. $30 plus shipping for a good seal.
Re: CB360 project
« Reply #168 on: Mar 25, 2017, 22:22:59 »
By the way, Eastwood Pre Prep works wonders on threebond. I just used a plastic razor for the bigger stuff and wiped the thin stuff right off with eastwood pre.
Offline crazypj
Re: CB360 project
« Reply #169 on: Mar 27, 2017, 15:45:00 »
That looks more than 0.0015", sure it wasn't 0.015"? (one and a half thou compared to fifteen thou)
 one and a half thou wouldn't be enough to cause a major leak (or even a mi or one)
Head was probably torqued in wrong sequence at some time, started on outside nuts instead of the 4 in the middle
« Last Edit: Mar 27, 2017, 15:47:02 by crazypj »
Best thing I ever overheard
Brian Morgan, 1982
