www.Moto-Madness.com
Author Topic: 1972 cb/cl 100  (Read 33990 times)
Offline Redliner
Re: 1972 cb/cl 100
« Reply #70 on: May 31, 2015, 03:32:31 »
Any matching plug to the original requirement will work. I think the 100 uses the thinner plug so it would be NGK code D8EA. Cross that number to other manufacturers and any matches will be fine. The D means it's 12mm thread, 8 is the temperature that the plug should maintain, and the others are fuzzy but I think the A means is a copper core or something, not really important just make sure you don't deviate. For instance, a DR8EA will muck things up.
I'm pretty sure I'd know if I were being manipulated by some overwhelming, mesmerizing, quasi-divine entity anointed by its own cult of personality. Nobody could be that stupid. So who's ready for the Super Bowl?
Offline JB77
Re: 1972 cb/cl 100
« Reply #71 on: May 31, 2015, 09:30:49 »
Thank you.
Offline JB77
Re: 1972 cb/cl 100
« Reply #72 on: Jun 01, 2015, 22:01:50 »
Picked up a new plug today, local store had it for $2.49. Super happy about that. I'll recheck things and see what happens tomorrow.
Offline JB77
Re: 1972 cb/cl 100
« Reply #73 on: Jun 03, 2015, 17:22:29 »
Recleaned the carb the jets and bowl, mixed in some new gas in the tank, new plug in, and a squirt of starter fluid and she ran. She's rough and bogs down if giving too much throttle. Haven't gotten her out on the road yet. Had the idle set pretty good, then she stalled. I'm now letting her sit for a few before I try again. Guessing I need to pull the complete Carb apart to make sure there is nothing gunked up in there somewhere.
Offline trek97
Re: 1972 cb/cl 100
« Reply #74 on: Jun 03, 2015, 22:55:50 »
did you check point gap and static timing?  If you can keep her idling for a bit check timing w strobe light.
Park her w exhaust pointed towards sun, on a "no breeze" evening.  When she starts to bog on throttle, watch exhaust for black smoke.  Black smoke says shes too rich and need to jet down.  Or keep her bogging for a bit.  Then check plug.  If its cleaner and white, shes too lean.  black plug = rich.
« Last Edit: Jun 03, 2015, 22:58:51 by trek97 »
Offline JB77
Re: 1972 cb/cl 100
« Reply #75 on: Jun 03, 2015, 23:07:49 »
I set the gap a couple months ago, before any attempt to start it. I didn't use a light to verify,  but I plan to recheck it this weekend. Thanks for the sun trick.
Offline trek97
Re: 1972 cb/cl 100
« Reply #76 on: Jun 04, 2015, 07:46:05 »
Its best to time w a light.  Ive found the static time is just close enough to get her started and running.  Not riding.  You may be surprised just how far off static time is once shes running.  And the light will show you shes advancing properly w rpm.
« Last Edit: Jun 04, 2015, 07:47:56 by trek97 »
Offline JB77
Re: 1972 cb/cl 100
« Reply #77 on: Jun 04, 2015, 07:59:36 »
I never realized it would run with timing off. I've researched and read the manual and know how to check the static timing with a light. How do I check it running with a strobe? Same idea? Do I just leave the light attached?
Offline JB77
Re: 1972 cb/cl 100
« Reply #78 on: Jun 04, 2015, 16:51:35 »
Ignore my ignorance, I looked up the strobe light.
Offline trek97
Re: 1972 cb/cl 100
« Reply #79 on: Jun 05, 2015, 07:15:38 »
I use a Craftsman I bought 30 years ago.
This should do it.. Stroboscopic timing light.
http://www.harborfreight.com/timing-light-with-advance-40963.html
Or just borrow one if you can.
