OK, the AGM $16 dollar battery came and it's too fat for the sidecover to go on. I stood the battery on it's end, it goes in that way just like the post on yahoo said. i'm going to try to move the airbox to the right a little and see if that frees up the space I need. I got a 15 amp mini blade fuse on it. The speedo bulbs are all out so i'm going to swap in some old 750 bulbs I have.
I read if the red/white wire isn't hooked up or the rectifier is junk the dyno will send as much as 17 volts to the lights. That explains the 12 volt headlight and taillight and the others all blown out. This bike had red/white on the neg. post. nuff said huh?
The cl100S sidecover emblem came, it's perfect. Except the other side has no S. oh well, you can't see them at the same time anyway.
I believe this beast would run on 12 volts with the stock stator, given a good battery, rectifier and regulator. Through all this the old stator tests good.
If watts are volts x amps wouldn't 12V double the watts of a 6 volt bike?
