www.Moto-Madness.com
Author Topic: Project "walrus" Yam XS 750  (Read 39186 times)
Offline Ryan Stecken
Re: Project "walrus" Yam XS 750
« Reply #340 on: Apr 19, 2017, 03:15:00 »
The clunk sound is quite distinctive.
I sometimes even feel "vibration" of some gears clunking together when I shift the gears,what I read in another forum that there is a screw that holds the shifter cam (behind the clutch basket) that can come loose...I dont know If I want to go back into the clutch again...
Offline XS750AU
« Reply #341 on: Apr 19, 2017, 04:47:25 »
Hi Ryan
You get to that screw through the sump. No need to touch the clutch.
Sent from my SM-G900I using DO THE TON mobile app
“Engineering is the art of being approximately right rather than exactly wrong.”
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #342 on: Apr 19, 2017, 07:20:16 »
Let's have a listen on Friday, shall we? I suspect you just have to get used to the amount of mechanical noise your engine makes.
My Blog:
« Reply #343 on: Apr 19, 2017, 07:30:51 »
Alright man!cant wait!
Gesendet von meinem SM-A310F mit Tapatalk
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #344 on: Apr 19, 2017, 08:25:45 »
I admit though, that the 850 you didn't take was probably the quietest Yam Triple I've ever heard...  :P
(I shall fire mine up today or tomorrow just to have a valid comparison!)
My Blog:
« Reply #345 on: Apr 19, 2017, 12:20:09 »
Before I take anything apart I will check on my clutch actuation adjustment (under the plastic side cover).
The problem got worse since I swapped to higher bars ...the clutch cable will be swapped to a longer one so I guess this could cause the clutch to drag sometimes (too short clutch cable).
The gas cable is way too short and causes the bike to gas when I turn left or right the tightely :-) pretty funny when you pull up to your friends and the bike revvŽs up like hell when the bike is parked  :D
« Reply #346 on: Apr 25, 2017, 03:41:48 »
So guys!
Great news on the XS front.
The "cracking" gears stopped after I readjusted the clutch actuation screw.One turn out and it got WAY better
Had my friend "Der Nanno" coming over redadjusting the valves ( they were set completely wrong), readjusting the ignition and syncing the carbs.Now the baby starts first kick even when the engine is cold.
Since I swapped to higher bars I had to order new bowdens for gas and clutch and currently waiting for them.
Bike is supercomfy now with the new bars.
I have the plan to ride with this bike to my Bachelorparty in Zagreb (Croatia) this summer, so it has to work properly or I will strand somewhere  ::)
One thing I still need to do is dropping the needle clip, it looks like the bike is running a bit lean in the mid throttle area.
I already took the needles out but there is a plastic piece (maybe its a shim) in there which I cant really eyeball what to do with it.
Under the plastic piece there are still 2 notches to adjust the needle so maybe I just need to take that out...
What are your thoughts on these?
« Last Edit: Apr 25, 2017, 03:43:51 by Ryan Stecken »
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #347 on: Apr 25, 2017, 09:00:27 »
Simply adjust the needle as you would on the RD, the plastic bobbin is just a retainer (of sorts) and will not affect jetting.
Cheers,
Greg
My Blog:
Offline Garc
« Reply #348 on: Apr 25, 2017, 18:06:05 »
Running pods and 3-1 open MAC I had to richen the needle a notch from factory on the MKIIs.  132.5 was plenty of main on the big end with my 750 jug set.
XS 750/850 Triple Shaftjacker
« Reply #349 on: Apr 25, 2017, 18:22:59 »
Thanks garc!I'm runnin' different carbs on that bike from a Triumph Sprint 900...make quite a difference honestly to the old miks :-)
