Rick's 1975 Norton 850 Commando MkIII Roadster
Sidecovers, levers, handlebars and headlight removed.
Carbs, wiring harness, coils, and all electrical bits removed.
Brakes, headers, wheels & forks removed
Parts to be powdercoated.
Parts to be cleaned, refurbished and/or replaced (wiring harness, mainly)
Carbs & brakes to be overhauled. Chain will be replaced.
From 10/12/16
L - R: A few bits to be polished, rubber bits, tub of fasteners & bits to be cadmium plated.
Shelves filling up fast!
10/13
Battery tray is quite rusty and scruffy, as are the horn & mounts.
This is the area you never see on a Commando!
Battery tray, oil tank, and shocks removed.
10/13
Ready to dig into the primary chaincase...
Looks a bit neglected, black oil
Shifter crossover shaft was well and truly rusted to the coupler, regardless of the rubber bootie. The replacement bootie will get a bit of RTV silicone to seal it up.
Clutch plates are not too bad; they'll clean right up.
With the alternator, starter drive bits, and primary chain tensioner removed, the primary just needed the usual alternator rotor and drive sprocket pullers, and off it all came.
Front isolastic is sacked and deteriorating.
Still 10/13...
Power unit free and clear.
Not much left to get down to the bare frame...
Tranny liberated from it's cradle after removing the oil filter head.
10/13
Primary drive and transmission (tranny yet to be torn down and inspected)
Pulling the rear isolastic was easier than I anticipated, the through bolt wasn't frozen inside the iso sleeve as is very typical. Swingarm spindle slid right out. That's it, bare frame!
10/14/16 Engine disassembly-
Timing cover was nice and clean, just a bit of sludge at the bottom.
Absolutely zero baked on / blackened oil; this bike got decent regular maintenance and was never thrashed.
Very little sludge in the timing chest, one of the cleanest I've seen, 20+ Commando engines overhauled.
10/14/16
All of the cam drivetrain and oil pump removed.
Like new, not even a hint of oil in the rockerbox covers (rockers and valve springs have a nice film of clean oil on them)
Champion N3C are incorrect fitment. Right plug just a touch lean, left side a bit rich. Readings may be off, due to incorrect plug spec (should be N7YC).
Piston tops are somewhat typical, scaly carbon buildup. I've seen a LOT worse...
Combustion chambers also look very typical, maybe a bit rich.
Cam followers have only a hint of center line flat spotting (if you can even see it)
Cylinders are in good shape, no scratches at all. Need to mic them.
Tops of the bores are a bit surface rusted; pistons were parked at the bottom of the stroke.
Pushrods are in very good shape, zero scratches / gouges.
From 10/14/16
Back sides of the rods show just a bit of scuffing. I'm sure this must have been how they were installed, this engine has never been disturbed.
Front sides of the rods nice and clean. ZERO evidence of small end heating which turns them brown or even black. These are just a bit yellowed.
Bottom of the engine shows it had some life-long oil weepage which caked on pretty significantly.
Piston front faces show witness discoloration where the cylinder skirt cut-outs reach (I didn't think they went that high up). I've never noticed this prominent coloration. No significant scuffing or scratches.
Piston rear faces look pretty much like the fronts.
A bit of blow-by on the piston sides. At a minimum, the bike will get new rings (still need to mic everything).
Left case half looks pretty decent, just a faint residue of sludge on the bottom. No chips, chunks, sludge or dirt.
Right case half looks just like the left. Superblend main bearings are in excellent shape.
The crank has been liberated from the cases.
Cam lobes look excellent, zero wear
The other two lobes look great.
Crank main journals look near perfect, zero scratches.
Virtually zero sludge in the crank trap. Just a bit of gooey, dark oil.
Hardly dirty sludge trap.
Rod bearing shells are in very good condition, just a bit of easy wear, no scratches. Almost all of my photos are right side parts on the right, left side parts on the left (same with head, plugs, pistons, etc.)
Just need to tear apart the transmission and head, carbs, and forks, and the disassembly phase will be done.
So THAT'S where all the sludge went in this engine! Yikes.
This is very typical of a Norton transmission.
Remember that rusted-stuck shifter shaft coupler? Well, it REFUSED to budge, so I cut it free (3 cuts).
Inner cover looks more normal inside the inner face...
Dirtiest place on the whole bike.
Last of the sludge, not TOO bad in the gearcase itself.
Transmission done. That's probably it till Monday.
Engine disassembled except for head & carbs.
End of a L-O-N-G day.
