CaferacerMO said:what's up with the sumo head light
Had it lying around. Original headlight was burned out so I figured why not.
teazer said:What size is that carb across the bore of the outlet? The oval bore measurements are more important but harder to measure to get the equivalent venturi size.
teazer said:They appear to be copies of Keihin PE24 carbs but copies often are different sizes than the originals. Could you please measure the bore of the outlet (engine side of the carb) - not the OD and if possible the diameter of the slide.
Thx
