1980 XT500 BUILD
MCKAY34
DTT BOTM WINNER
Hello everyone,
Starting a new build, picked this bike up last week. Its a 1980 xt500, however it doesnt have a matching engine. Im still trying to figure out what year the engine is. 1E6-302000 if anyone knows please let me know.
Plans for the bike.
- strip down, repaint and rebuild.
- 12v conversion
- virtually rebuild the entire bike, its pretty rough.
- I am going to use the bike for an extra run around bike and some off road trails.
The bike is pretty stuffed. it doesnt run or ride and my mechanical experience level is not great, so any help would be greatly appreciated
So lets get started!
WISH ME LUCK!!!!!
Cleared some space in the garage, so i have a nice clean area to work. and can start the strip down.
Started pulling it apart, the more i dive into this bike the more parts i relise i need to order.
no problems, so far. A few tough bolts here and there, but pretty easy so far.
also got the engine out !
its on my bench so i can work on it better, its the first thing im going to try and rebuild.
I was cleaning the oil pan/bowel thing and amongst all the crap. i found this chunk of metal. It scared the hell out of me. but after some research and diving into the motor a bit more i discovered the metal was the kick starter stop block. Apparently this happens a lot.
Anyway, i can add that to the parts list.
its pretty easy to replace, just 3 bolts. Further inspection, it doesnt seem to have done any damage.
i pulled the carb apart , i will do a full rebuild of this. and im hoping to get it hydro blasted. along with some other parts, so super excited to see how that turns out.
The carb looks to be in pretty good condition.
here is the kick starter piece that broke
ok at first glance does anyone have any thoughts on how this looks?
valves and piston.
i will be replacing the valves as soon as i can find out what year my engine is.
also one of the springs have snapped on the valves so i will replace all of that also.
any thoughts on the colour of this piston and valves, seems to be very black.
i cleaned the piston very easily, and looks ok
hey thanks for the reply.
how do you know its 1976?
i thought 76 didnt have the compression window. but this one has it
in the picture mind you my eyes are getting old
the spark plug threads look awful pls check and make sure its my eyes and not that you need a helicoil
MCKAY34 said:
Does anyone know what year my engine is?
xt500 number: 1E6 - 302000
According to this, looks like 1978..
http://xt500.free.fr/technique/numero.html
Sent from my XT1563 using Tapatalk
The spark plug thread is all good!
Checking that list, why would you say it's a 79?
Because the 1e6 number is also next to the 76 model?
1E6-300101-310000 2H2XT 500 E 78... If your vin is 1e6 302000 thst falls in between those #s doesn't it? So 1978.. That's just how I'm reading it maybe?
yep! thanks exactly what i have.
yamaha finally called me back. its a 78 engine. and my frame is an 80.
thanks to everyone! problem solved, time to keep kicking on with the build.
havnt posted in a while,
i have been waiting for parts to arrive, just been tearing more bits apart. did some painting while i have been waiting for parts to arrive.
did some painting while i have been waiting for parts.
going with satin black for the engine.
