Despite it being 42 degree's, I had a day off and I was determined to get some work done on the bike!
This is the standard chain guard. It is lame. I thought I could do something with it, though I do intend to make one out of ally sheet later. The white mark is where it will be cut.
Once cut and shut, and with a coat of bumper paint it looks much better. I drilled the rivets out and gave the steel support a trim with the grinder so it didn't hang over the edge and then gave it a coat of gloss black.
On the bike it looks pretty neat.
I also mounted a little ally box in front of the battery for the fuse box, relays, etc.
I finally settled on a position for the regulator to go where it's in the airflow but out of sight. I will make up a better triangulated bracket later to mount it, but for now it's okay sitting on a bit of flatbar.
The biggest job I did though was to start making the upholstery pan. To start, I drilled the holes to attach it in the seat pan, and layed some chop mat on top, roughly trimmed it to size.
I then pushed some m6 x 15 cap head bolts (that I'd ground the heads off of) through with a washer under each.
Then once the first layer of chop mat was impregnated with the resin, I stuck extra layers of chop mat over where the bolts sit and stuck them in with resin. Once this layer is dry I will glass another layer on to finish the piece, as I ran out of resin today.
This will then have foam stuck to it, which will be shaped, then I will upholster it. Yay!
