So my pipes are at my brothers house to have the mufflers welded on and I got my header wrap in the mail today. Titanium wrap with some extra ties. I also tried the Gunk branded engine cleaners and the gel one seemed to work a little better than the foaming one. I had to go back over with a brush and carb cleaner to get into the fins good and I missed some but I'm in Indiana so the warmer days are hit and miss in the winter. It's supposed to be in the 40's again this weekend so I may try to clean it again then just to get into the fins a little better.
I cut the foot peg off the bracket for the kickstand and painted it just so it wont rust really bad until next year when I send all of it out for powder coat. This will relieve me from having to use the bike jack when I take the center stand off.
I also go the tank mounted. I had an extra velocity stack from when I rejetted my 95 magna deluxe because I damaged one when I was removing it so I used about 1' of that and cut it in half and used the factory rubber tank mounts to mount the fiberglass tank. I also adhered 2 screws onto the tank towards the rear to hook a strap around the bottom of the frame to hold the tank on. Also installed a smaller piece of flat rubber from the tank to frame in the rear to prevent all the vibrations from the tank. Most of these things will be hardly noticeable or not noticeable at all when I'm finished.
I started to mount the seat and got the mounting plate installed about halfway. I am still going to put 2 more bolts into it and then get my seat mounted.
After I get the tank and seat mounted I'm sending those out for paint. The tank, seat, headlight bucket and the items to be painted. Maybe the headlight ears. After paint and clear I'm having a friend that is a master pin stripper do the design on all of those parts and then it's going back for a couple more layers of clear. Then those will be done.
I ran into a problem slightly with the mikuni vm32 carbs when attempting to install them, first the carbs will not install with the choke levers which was already known but then the factory carb boots were a little harder and dryer than I wanted to try to crimp them down onto the carbs so I ended up buying new boots and those will be installed soon.
I will try to post more pics as I go along. Thanks for looking!!
