Hi,
My new project is comming this weekend and these need to go.
10$ each item
40$ for 5 items
70$ for 10 items
Every parts are in good condition. I've put a side parts that wasn't nice.
Feel free to ask some pictures if interest. I won't tke 50 picture jsut for fun!!!!! ;o)
- 1978 cb750k speedo (have some pitting on the chromoe side)
- 1978 Cb750k tacho (have some pitting on the chromoe side)
- 1978 Dash with light (need painting)
- 1978 complete triple tree
- 1978 complete electical board and all related components
- Chrome side stand (but will need to be rechrome)
- Chrome center stand
- Inner rear fender
- 1978 Oil tank
- 1978 gas throtle handle
- 1978 clutch lever
- Chrome brake pedal
- Ignition with key
- 3 pair of bronze bushing for swingarm
- 2 set of valve spring (one set is new)
- shifter lever
- original valve cover. Very vey clean (non polish)
- 2 polish valve cover (a little bit rough but a little polish would bring them nice)
- complete 1975 head with cam and rockers (valve are missing, head is good but with carbon deposit to clean)
- 1975 complete electical board and all related components
- complete 1975 cb750k wiring harnest
- 1975 cb750k tacho
- 4 battery straps
- 2 primary chain guide (one is new)
- 2 new piston rings parts #13021-300-014
- 2 new full sets of piston pin parts #13111-300-000
- 1 new piston in box
- 1 new tacho gear
- 4 new valve (the biggest one)
- New primary chain part # 23131-300-315
- 3 cam gear
- 2 set of oil hose
- complete oil cooler adapter with hose (missing the radiator)
- 1975 master cylinder
- 1975 cluitch lever
- 4 set of used clutch
- 2 full set of gear box including 5 speed transmsision plus every gear you can find in the motor (kick start, ect...
- 2 rotor
- 2 point system
- 1978 cb750k handle bar (pretty wide)
- 1975 cb750k triple tree
- 1975 front black forks. Will need new seal and a little of putting in the upper part.
10$ each item
40$ for 5 items
70$ for 10 items
- Inner rear fender
- 1978 Oil tank
- 1978 clutch lever
- Ignition with key
- shifter lever
- 1975 cb750k tacho
- 4 battery straps
- 1 new tacho gear
- 3 cam gear
- 2 set of oil hose
- 2 rotor
- 2 point system
