Name that tool (please)
mysta2
Over 1,000 Posts
DTT BOTM WINNER
Seriously. I don't know what this is. I own it, at one point I felt the need to buy it, probably even special ordered it, maybe even used it.
I thought it was a special service tool for either my CL360 or CB750. But I'm becoming less sure of that as time goes on without an answer.
Could be a bicycle tool.
Strip some bikes down until you find a recess with two indents for the tabs on the tool down in a hole about and inch deep.
No matter where you go, there you are.
I put my money on an oil pump removal tool, only thing i know that is not screwed in tight enough to be able to use your hand.
it's 4 inches long. The diameter of the working end is .31.
I'm fairly convinced that its a schrader valve tool. Which mean's its in the wrong section of my toolbox
Thanks!
I have several tools with the same function but are larger - you use them to remove bezels from gauges and such. There's probably a version of this for the bezel that goes around my CB350 ignition switch, although I just use some needle-nose pliers.
It's not a Schrader valve.
Oh, and the obligatory "Dyslexics of the World - Untie!"
Thanks!
not a shrader valve tool ::) it is a spoke wrench for when the spokes start protuding the nipples
Thanks!
The working end of that tool is the opposite of what a Shrader valve needs and at .31" diameter it'd never fit into the valve stem anyway.
The only spoke wrenches I've seen that work from that end of the nipple have a protrusion to center the end on the spoke, not a hollow to allow the spoke to protrude into the tool, and if you're spokes are so long they're poking through when they're still so loose you're using a tool on that end, you have the wrong size spokes.
My first thought was it looked like part of a set up to hold a degree wheel onto a crankshaft, but there's no need for it to be knurled and knowing the size now, it's too small for that.
Yup - my thoughts are that it's a tool to use on the butt end of the spoke nipple. Better than mucking up your nice fancy anodized or painted nipples with a traditional wrench, if your tire isn't on.
Spokes are sometimes too long - I've had to grind a number of Buchanan spokes down a bit to ensure no potential damage to the rim strip / tube.
Can't agree on the spoke nipple screw driver, as proper spoke selection would prevent the spoke from existing the nipple into the tube zone. My guess is a Shrader Valve ring spanner to tighten the holding ring against the rim. The outer diameter of a Shrader valve is 8 mm or 0.31". ;)
I have used something similar for holding counterbore internal thread flanged nuts like this. but with a flat surface on the flanged end.
th
