this bolt on kit is in better condition than you would expect to find used parts in
rockerbox and cam journals, have had gasket surfaces cleaned up.. cam to journal running clearance is right near new on one end .002" and about .003''- the otherer end
cam lobes and rocker faces have been lightly blasted with al oxc fine nedia and had moly/graphite applied as a counter to the alarming number of spodes who start up a bike cold pin it and panic rev it
timing sprocket is in good shape,this cam rocker box kit will bolt on any 350 twin,more cammy more power on top end high revs
cam endplay has been set down near minimum,thats why the nos hopnda gaskets arer included ,i will mAlkso include a cam seal everything will bne clean and ready to assemble
i dont recomend it for the kick only sl unless you get something bigger than 24mm carbs
but it will not work with 312 rockersdor sprocket hence the hanydy kit
$400 + shipping
$400 + shipping
