1971 Honda CL350
Re: 1971 Honda CL350
What's your location? I'm in Florida and hsve two sets of 350 forks.
Sent from my SPH-L900 using Tapatalk 2
Thanks for the offer
I am considering different alternatives and will get back to you soon
How much would you like for the set?
BTW I have been following your rebuild thread and Crazypj and am very impressed with both your work!
I love the drilled hub/vents
Thanks! Its been slow going but it'll get done eventually. have two different sets of forks. I'll have to send you pics tomorrow.
Learning and Progressing
We are progressing
The engine is out and the frame is partially stripped
I disembled the front forks and polished the rust off one tube. There is still some etching present even though it is relatively smooth. I don't know if I need to replace them-probably
I put alot of work into the swing arm
I learned some tricks:
1. To remove the bushings-there is a 1/4" space between the bushings on each side. You can get a chisel on the edge of each and easily pound it out. You have to be careful to avoid injuring the housing.
2. To remove the rear shock bushings-drill out the core. My drill was too small so I kept angling it. By the time the center is drilled, the rubber starts smaoking and you can core it out with a screwdriver. Then cut two slits with a hacksaw through the outer housing -90degrees apart and the outer ring comes out easy. Again you have to be careful not to cut the housing with the saw.
I imagine most readers know these tricks but it is fun learning them and getting good results!
