1982 CB900F rear brake caliper options?
TheDirtyJuan
Hey found out my caliper rear brake caliper is dunzo. Does anyone know where to get one? Or options of ones tht can fit?! Thanks in advance!
Post a want ad in the "buying" section. Do yourself a favor and cross reference the part number as well. Honda loved using the same part across the model range if possible. Likely this caliper was used on the 750s of the same time period, probably other bikes too.
Calipers are simple, 2 seals on that, 2 pistons, a banjo fitting and a bleeder.
Takes a bit to ruin a caliper.....
Why do you think the caliper is bad? Stripped the threads?
Not sure, the Pistons are taking a lot of effort to move and are not moving freely, could I just rebuild them? Im so knew to all of this I just got this bike and been trying to fix everything. I just wanna ride this thing already!
Rebuild a caliper is relatively easy. All the parts are available from Honda...
http://www.houseofhondaparts.com/fiche_section_detail.asp?section=2563885&category=Motorcycles&make=Honda&year=1982&fveh=132907
