Texas Two Step Taco
Wheelie Bar construction complete
9.2 lbs motorcycle wheelie bar weight can be lighter with aluminum rod ends on the upper push and titanium bolts
That looks good but a little heavy. It will be fine though and for the mark 2 version, once the bug bites hard, it can be made out of aluminum tube
Yep should have used aluminum but I see where this addiction goes ....to your wallet! lol!!! Thank you for all your help. I think subconsciously this maybe a way to finally meet you in person! Wheelie bars are set at 2”. Keep our good friend Brian Hobbs in your thoughts he has done a ton of work on BB’s bike. He had a brain aneurysm yesterday and is in ICU.
Well let’s see how this runs On c12 32-1 using alco semi synthetic no smoke oil
Do I stand a chance against the Ducati 900ss https://youtu.be/W2Xo9Cnks_Q
Sorry to hear about Brian Hobbs. Will keep him in our prayers.
Tip in some U4.4 and watch that bike fly. C12 is a good safe race gas but not exciting. I wonder what fuel BB uses in that 7 second beast that Alex Hughes rides for him. We are not allowed to use oxygenated fuel which is a bummer. I'm tipping all my old 4.4 into the lawn mower. Smells like being at the drag strip every time we mow the lawn.
Do I need to rejet for u4.4
Supposedly. How close is the jetting now? If you are rich now by 2-4 main jet steps, you will be fine. If it's lean now, a bigger hole would be a great idea.
Zeke is kicking my tail...need to change my front sprocket to a 13 not getting out of 3.
Time to get in touch with some internal aggression - and change the gearing. :)
Zeke just keeps getting faster on the Ducati 900ss
Launch was right upper end detonation. To much throttle? Had the Harley at the beginning on another run got schooled by a gixxer https://youtu.be/sQxLXOUQjlY
Dropped the clutch... https://youtu.be/KbTQa4BZpsM
Just some highlights put the C12 race fuel in the Bultaco and it started backwards from the Kickstarter every time. Had to push start all night. The rpm tell tale said 10,800 was max so I was twisting off a little too much probably why I had the detonation.
Ok gearing is way better but driving 4 hours to get the heavier flywheel https://youtu.be/QL0BVG9O_Uo
