Leds have a very different beam pattern a require a mirror and lens and normally a reflector that actually put the light where it needs to.
I love you ingenuity but brighter isn't better. A lot of science and research goes into sealed beams to perform with the incandescent bulb in them. I'm not trying to rain on your parade, but you might find that the reflector scatters the light more than focuses on the road in from of you. It's all about cutoff and focusing on the ground in front of you where the road is coming at speed. If you don't plan on using it at night, it will probably do great as a drl but I dunno if I would trust it for a night ride.
I have done tons of led and HID retrofits, when I first got into it I thought it was as simple a bulb swaps, but there is so much more.
Head over to the retrofit source and read up on some of the forums, there's tons of great info and quite a bit of moto related threads. A lot of guys are really knowledgeable. If you email the guys at the store, they are always more than happy to help and "dumb down" some of the science to help you make proper purchases and they are amazing in the customer support side
The store
https://www.theretrofitsource.com
The forum
https://www.hidplanet.com/forums/
