Im not using led. They are all hooked up. If they werent grounded properly would they turn on at all? Not exactly sure what type of flasher it is, i know its a 12v and thats it.
Have a look at the flasher relay - it should have markings on it like 12v, 4 x 21W if it is a stock relay. That means it needs 4 x 21 watt bulbs to have enough load to function. If you are using 10w bulbs it probably wont trigger it.
I got my signals to work! Turns out the po put in the wrong bulbs and the flasher was toast. Now i got a new problem. The yellow wire from the regulator gets really warm when the bike is on. What could that be?
