1979 kawasaki kz400 LTD
grimlock
Whats up members, I have come across an issue and hopefully someone has gone through it and can help out.
When i purchased my bike it came with no mufflers and it started right away but the problem was that it was too loud.
I work at 4am and didn't want to wake up the neighborhood so i installed some biltwell mini's. I turn it on and it started but
then it died out and would not turn back on. I sprayed starting fluid in the pods and it sounded like it wanted to turn but it didn't.
My guess is that i need to re jet it for mufflers and i have no idea how to do that. someone told me i can buy a 2 into 1 carb and
that it would fix my problem. Right now i have the battery charging because it drained from all the failed starts.
Thanks in advance.
Installing mufflers isn't going to cause that... to test just remove the mufflers and try it.
When installing the mufflers you may have accidentally bumped or loosened something or it might just be an unrelated coincidence.
Check the normal things:
Does if have gas?
Is the fuel valve turned on or at reserve?
Did it blow a fuse?
Does it have spark?
Also... some bikes have a kickstand switch that won't let them start if the kickstand is down, some have to have the clutch pulled in, etc... maybe a switch went bad or maybe you bumped something like a kickstand switch while you were putting the muffler on. (I'm not familiar with that exact bike so just guessing here)
Sorry to be so basic but sometimes we get focused on an issue that doesn't exist, we all do it. It's probably just something simple.
It has gas, it is on reserve (just to make sure it's getting gas), the fuses are fine and the spark plugs are good.
The bike turns on with the kickstand down all the time. Also it turned on the first time I turned it on after installing the mufflers but it died like if the choke wasn't turned enough but it was turned all the way up because halfway like normal wasn't enough
Thanks for the debunking methods.
**update**
I took the mufflers off and it still wouldnt start.
My battery started getting hot and it started hissing. i'm assuming this is the problem. Just a coincidence that it crapped out when i put the new mufflers in.
I'll update again when i get a new battery.
